Flow Diagramming Components >> ASP.NET >> How to get Origin Id
https://mindfusion.eu/Forum/YaBB.pl?num=1324963331
Message started by honghuhuang on Dec 27th, 2011 at 5:22am
Title: How to get Origin Id
Post by honghuhuang on Dec 27th, 2011 at 5:22am
I have a problem and I did not know how to solve it. Who can help me?
The problem is: when I drag two shape nodes to the canvas and connect these two shape nodes , What I want is that when I double click the son shape node ,How can I get the parent shape node id?
Title: Re: How to get Origin Id
Post by Stoyo on Dec 27th, 2011 at 7:03am
You could check the incoming links collection of the double-clicked node, and then the origin of the first link:
var node = e.getNode();
if (node.getIncomingLinks().size() > 0)
      var linkFromParent = node.getIncomingLinks().get(0);
      var parent = linkFromParent.getOrigin();
      // do something with origin
}[/code]
I hope that helps,
