Grid and Spreadsheet Components >> WPF >> Copy merged cells
https://mindfusion.eu/Forum/YaBB.pl?num=1470900227 Message started by sm.eagle on Aug 11th, 2016 at 7:23am |
Title: Copy merged cells Post by sm.eagle on Aug 11th, 2016 at 7:23am
It's me again,
Continuing from the last topic, I noticed that merged cells are not transferred when copy/pasting worksheet content. How can I remedy that? Cheers, Sam |
Title: Re: Copy merged cells Post by Meppy on Aug 11th, 2016 at 10:55am
You need to copy and paste the merged cell data manually. For this purpose, define a new MergedCellData class, tagged as [Serializable], which will hold the merged cell information: Code (][Serializable):
Note that, along with the merged cell ranges, the class also contains the top/left of the selection range. This is done so that the merged cell ranges can be offset appropriately when pasted. Now, in the Copy method, collect all merged cell ranges within the selection in the active worksheet: Code (]var mergedCells = activeSheet.MergedCells.Where(mergedCell => Contains(selectionRange, mergedCell)) .Select(mergedCell => mergedCell.ToString()).ToList(); var mergedCellData = new MergedCellData(mergedCells, selectionRange.Left, selectionRange.Top); dataObject.SetData(mergedCellData);[/code):
Let me know if this helps. Regards, Meppy |
The MindFusion Forums » Powered by YaBB 2.6.11! YaBB Forum Software © 2000-2025. All Rights Reserved. |
