This program mostly be a good xml editor really, despite it is meant to be a 'viewer' rather.
So I'd like to suggest some more feature like this:-
- Use [Insert] and [Ctrl] + [Insert] to add a new node under or beside the current node. (Currently there is only right click to do this.
- Remind and confirm if we are going to leave all edited item to 'New' XML. (I just lost my work when I press [Ctrl] + [N])
I like user interface design of WMHelp XMLPad and would like XML Viewer to get some of them.
However, I know that this is 'Viewer' not 'Editor' and the editing function is just surplus, not main feature.
I appreciate the simple editing function in XML Viewer.
Try XML EditPro for "tree editing function"
Try XMLPad for UI and other features (if you plan this program to be XML editor in the future
Merging all good features together will come the best XML Editor.
Will add more once I get new idea
