Very Hot Topic (More than 25 Replies) proerties "locks up" (Read 25659 times)
Martin Gravråk
Guest
May 22nd, 2006 at 9:34am
For some reason most of the design-time properties on my calendar just "disappears" (see attached picture) after a while even without me touching them. Great control, but we cant use it keeps locking up like this..
Martin Gravråk
Guest
Attached picture
Reply #1 - May 22nd, 2006 at 9:43am
[img]http://stud.aitel.hist.no/~margrav/pocketplanner.gif[/img]
Re: proerties "locks up"
Reply #2 - May 22nd, 2006 at 10:28am
From the picture you have attached I deduce you are using VS 2005. The PocketPlanner for .NET Compact Framework v.2 comes with an additional dll, called 'PocketPlanner.PocketPC.asmmeta.dll'. This dll contains only design-time information and is crucial for the proper behavior of the control in the IDE designer. It looks like that for some reason this dll is not found by the environment and all the design-time support is lost.
What I can advice you to do, is to double-check whether the dll is present in the same directory with PocketPlanner.dll. And if that the case, you can try installing the metadata dll in the Global Assembly Cache (GAC), which is usually located in <windowsDir>\assembly\.
Let me know if this helps.
Martin
Re: properties "locks up"
Reply #3 - May 22nd, 2006 at 10:52am
The 'PocketPlanner.PocketPC.asmmeta.dll' is in the directory, and copying it to the GAC did not help.
It seems to be something in the designer.cs file or something like that, because if we open the project on another computer (w/ pocket planner installed) we get the exact same problem
Martin
Reply #4 - May 22nd, 2006 at 11:03am
We also tend to get
System.NotSupportedException was unhandled
Message="System.Globalization.DateTimeFormatInfo"
exeption in
      this.calendar1.DateTimeFormat = ((System.Globalization.DateTimeFormatInfo)(resources.GetObject("calendar1.DateTi
meFormat")));
while trying to start the app
Reply #5 - May 22nd, 2006 at 11:21am
Can you please try changing your regional settings from Norway to English and test if it works then?
Martin
Reply #6 - May 22nd, 2006 at 11:41am
did not help  ???
But if I add a new calendar to the same project (acually the same form) it works just fine. Unfortuantly this is not a good fix for the problem since it keeps happening all the time, and that new calendar is probably just going to lastst for a few hours at best.
Reply #7 - May 22nd, 2006 at 12:01pm
Is it possible to send me an application where the calendar is already broken and one which is still working fine? You can send them to support@mindfusion.org.
Thank you very much.
Martin
Reply #8 - May 23rd, 2006 at 7:43am
Unfortuantly I cant send you the application, but if it continues I will create a new application, mess a bit around width it and send you the project when it breaks.
It does however seem like I have found a "solution" for it, if I delete [i]
this.calendar1.DateTimeFormat = ((System.Globalization.DateTimeFormatInfo)(resources.GetObject("calendar 1.DateTimeFormat")));  [/i]
from the designer.cs it will work again, but the properties is usally a mess, so i end up having to set them again allmoast from scratch every time the calendar locks up.
Reply #9 - May 23rd, 2006 at 10:29am
If you have time to create a new application and send it to us when it breaks, this would be of great help for solving this problem. Thank you again for your persistence.
Martin
Reply #10 - May 26th, 2006 at 8:42am
We found the problem, two computers with pocket planner installed (in slightly different directories) and source-control with the help of source-control visual studio messed up a path in the solution file
andersco
Reply #11 - Jan 25th, 2009 at 4:45am
I also have the dateformat issue:
Can you elaborate on what you changed in the solution file to fix it?
Thanks!
Reply #12 - Jan 26th, 2009 at 7:31am
We disabled the design-time serialization of this property some time ago because the Compact Framework fails to deserialize it at run time. If you have the most recent version of PocketPlanner, try deleting this line and run the application again.
andersco
Reply #13 - Jan 26th, 2009 at 6:03pm
Yep, deleting the line fixes the problem but it is just annoying because every time I modify the calendar control the line gets added back in.  Is there any way to disable that or prevent it from being added back in?
Thanks.
Reply #14 - Jan 27th, 2009 at 7:33am
We disabled code generation for this property in one of the later releases.
What version of PocketPlanner are you using and what version of the CompactFramework?
Thank you,
