Normal Topic "Masterchart trial version" on the chart (Read 9443 times)
dhanalakshmi
Aug 8th, 2007 at 4:34am
Is there a way to remove the caption "masterchart Trial Version" on the Barchart or any chart
Re: "Masterchart trial version" on the c
Reply #1 - Aug 8th, 2007 at 6:28am
There is no way to remove it if you are using the trial version. If you have purchased the licensed version, update the project's reference path so that it points to the licensed dlls.
dhanalakshmi
Reply #2 - Aug 8th, 2007 at 6:36am
Thanks a lot Stoyan
