Normal Topic Right arrow at the top isn't floating to the right (Read 5054 times)
gerardo
Oct 18th, 2007 at 6:10pm
Using the view TimeTable in the calendar when I have the PPC in portrait mode and displaying the buttons to move between days in the header of the calendar. If I change the display mode to landscape on the PPC, The button in the header to move to the next date (right arrow) isn't redrawed according to the new layout of the screen. It remains in the position where it was in portrait mode, that is basically in the middle of the header in landscape mode.
Any ideas!!
Re: Right arrow at the top isn't floating to the r
Reply #1 - Oct 19th, 2007 at 4:37am
Try to change the orientation in a BeginInit/EndInit block as in the following code:
calendar.BeginInit();
// Switch to landscape
calendar.EndInit();
An alternative would be to invoke Calendar.UpdateLayout after the orientation has been changed:
calendar.UpdateLayout();
Let me know if it is working.
gerardo
Reply #2 - Oct 19th, 2007 at 11:46am
Thank you ...
Working Perfect using
BeginInit
EndInit
any time the calendar is resized.
