Hot Topic (More than 10 Replies) Export Chart to MS Excel or MS Word (Read 15617 times)
John_D
Apr 21st, 2008 at 1:15pm
Hi, I am looking use the charting product, is it possible to export the chart after it is populated with data to MS Excel or MS Word to be incorporated into a report for example.
Re: Export Chart to MS Excel or MS Word
Reply #1 - Apr 21st, 2008 at 2:05pm
Masterchart does not support the Word and Excel file formats. You could use the CreateBitmap method to get an image of the chart, then call Image.Save to save it to a file. Finally embed the image file into the Word/Excel reports using the MSOffice Automation API.
bjawnie
Reply #2 - Apr 6th, 2009 at 3:11pm
I am facing the same challenge.
Could you possibly provide an example of how we can save an image to Excel or Word?
Reply #3 - Apr 6th, 2009 at 4:08pm
Here is a sample showing how to add an image to Word file, using OLE Automation:
http://www.codeproject.com/KB/aspnet/word_automation.aspx
bjawnie
Reply #4 - Apr 8th, 2009 at 10:53am
Thanks for the prompt answer. I can't get it working however.
So I found an alternative way to archieve what I want. I am going to save my chart, a radar chart, to disk and the load it via iTextSharp and save the whole thing as a RTF document.
Unfortunately I am having trouble saving my radar chart. I am trying to save it by first getting the data with GenerateMetafile. However since I am not  rendering the chart as html I am a bit stuck.
Any help would be greatly appreciated. To sum up I need to save my radar chart to disk without rendering it as html.
Reply #5 - Apr 8th, 2009 at 11:26am
Are you using the ASP.NET version?
bjawnie
Reply #6 - Apr 8th, 2009 at 11:42am
Yes, precisely.
Reply #7 - Apr 8th, 2009 at 12:16pm
This version adds CreateBitmap and CreateMetafile methods to the WebForms.Chart class:
https://mindfusion.eu/_temp/webcharting_createimg.zip
You could call them to get an image of the chart and then save it to a file using the Image.Save method.
bjawnie
Reply #8 - Apr 12th, 2009 at 4:01pm
Thanks a lot. This seems like the right way, however I am not able to get it working. I get a lot of conflicts with MasterChart.dll and new dll's.
bjawnie
Reply #9 - Apr 13th, 2009 at 12:10am
I decided to start from scratch again and this time I got it working without the masterchart.dll file.
Thank you very much for the help : )
Reply #10 - Apr 13th, 2009 at 9:09am
Sorry, I forgot to warn you about the new naming convention we are using now ...
