Hot Topic (More than 10 Replies) Save/Load not working (Read 12217 times)
jovi
Aug 21st, 2009 at 3:11pm
I was trying to make a test with the LoadFrom and SaveTo functions. I took the code from the "Resources" samples and add a SaveTo call at the end of the Load event of the form. Then I tried to load the info again and it seems to work, but I do not see it on the calendar component. Any ideas?
Here is the code for the load event of the form:
#if LOAD
           calendar1.LoadFrom(ApplicationPath + "settings.xml");
#else
               Contact contact1 = new Contact();
               Contact contact2 = new Contact();
               Contact contact3 = new Contact();
               contact1.FirstName = "Douglas";
               contact1.Id = "CNT42ACF69F-B960-01A7-0157-6C164E5C4880";
               contact1.LastName = "Clark";
               contact2.FirstName = "Jayna";
               contact2.Id = "CNT4B73E527-617A-3F7A-0128-00812F2A5735";
               contact2.LastName = "Silversteed";
               contact3.FirstName = "Joe";
               contact3.Id = "CNT7EC7F660-70EE-43E7-0232-A3F15CAF6C78";
               contact3.LastName = "Timberwood";
               calendar1.Contacts.Add(contact1);
               calendar1.Contacts.Add(contact2);
               calendar1.Contacts.Add(contact3);
               Location _Location = new Location();
               _Location.Address = "3175 Av Cote de Liesse";
               _Location.Id = Guid.NewGuid().ToString();
               calendar1.Locations.Add(_Location);
           Appointment app = null;
           Random r = new Random();
           for (int i = 0; i < 20; i++)
               app = new Appointment();
               app.StartTime = calendar1.Date + TimeSpan.FromDays(r.Next(10) + 3);
               app.EndTime = app.StartTime + TimeSpan.FromHours(24 + r.Next(24));
               app.HeaderText = "Resource " + i.ToString();
               app.Contacts.Add(calendar1.Contacts[r.Next(3)]);
               app.Location = calendar1.Locations[0];
               calendar1.Schedule.Items.Add(app);
           calendar1.SaveTo(ApplicationPath + "settings.xml");
#endif
Re: Save/Load not working
Reply #1 - Aug 21st, 2009 at 4:03pm
Does AplicationPath end with the path separator symbol? Could you check if there's any appointment data saved in settings.xml after SaveTo?
jovi
Reply #2 - Aug 21st, 2009 at 4:08pm
Hi, thanks for your quick answer. Yes, all the appoitments, contacts and locations are there, and I can see them on the "watch" while debuggin in Visual Studio. I just can not see them on the component...  Embarrassed
jovi
Reply #3 - Aug 21st, 2009 at 5:18pm
I again. I realized that after loading, the calendar1.Schedule.Contacts collection has 3 elements, as expected, but calendar1.Contacts is empty. Is this the expected behaviour?
Reply #4 - Aug 24th, 2009 at 6:15am
Unfortunately, at this time the Calendar.SaveTo does not save view-specific information such as the resources selected for grouping. You have to manually reestablish this information upon loading.
mberger
Reply #5 - Jan 12th, 2010 at 11:52am
i have the same problem, Could  you please explain how i reesatblish this information?
greez Marco
Reply #6 - Jan 12th, 2010 at 11:58am
You need to add the resources you are grouping by to the corresponding Calendar collection - Contacts, Locations, Tasks or Resources. For example, if you were grouping by all available contacts, you would write something similar to the following:
foreach (Contact contact in calendar.Schedule.Contacts)
      calendar.Contacts.Add(contact);
mberger
Reply #7 - Jan 12th, 2010 at 12:17pm
Hi Meppy,
thanks for your help! But thats not the problem, because the resources that i have saved in a binary file will be added to the ResourceCollection of the Calendar. But the calendar doesn't display them...
regards Marco
Reply #8 - Jan 12th, 2010 at 12:27pm
Can you post here the code you use for loading? Also, what view are you using?
mberger
Reply #9 - Jan 12th, 2010 at 1:16pm
I use the resourceView..., but i got it!!!
Thanks Meppy
Is it possible to set the width of the columns in the resourceview?
Reply #10 - Jan 12th, 2010 at 1:44pm
You cannot set the width of the columns directly, the width is calculated based on the displayed text. You can however scale this width up and down through the ResourceViewSettings.TimelineScale property. The default value 100 specifies no scale.
mberger
Reply #11 - Jan 12th, 2010 at 3:08pm
Ok...,
but now i have an other little Problem. When i define a new Appointment with a duration of 1 day,
i got problems with the Item-Width. I have set the ResourceLengthMode to exact. If i reduce the size of the application window, the resource-width fills the calendar. if i enlarge the application window, the resource disappears.
Reply #12 - Jan 12th, 2010 at 3:23pm
I am not quite sure what is the problem you are experiencing. Do you mean that the resource disappears or that the appointment disappears? Also, is this problem happening only when you modify the TimelineScale?
Sending me your Calendar settings and/or screenshots illustrating the problem might be helpful too. Feel free to send them to support@mindfusion.eu.
