Normal Topic Calendar throws an out of memory exception. (Read 4710 times)
jovi
Nov 12th, 2009 at 6:02pm
I am using PocketPlanner control, version 4.5, under Windows CE 6.0 R3, and I am getting an out of memory exception. I was able to reproduce the error in a sample application:
1- I added an Appointment with a recurrence like this:
Appointment _Appointment = new Appointment();
           _Appointment.HeaderText = "Testing...";
           _Appointment.Subject = "Testing...";
           _Appointment.DescriptionText = "Testing...";
           _Appointment.StartTime = DateTime.Now.AddHours(2);
           _Appointment.EndTime = DateTime.Now.AddHours(3);
           _Appointment.Attendees.Add(fCalendar.Contacts[0]);
           Recurrence _Recurrence = new Recurrence();
           _Recurrence.Pattern = RecurrencePattern.Daily;
           _Recurrence.Days = 2;
           _Recurrence.StartDate = _Appointment.StartTime;
           _Recurrence.RecurrenceEnd = RecurrenceEnd.Never;
_Appointment.Recurrence = _Recurrence;
           fCalendar.Schedule.Items.Add(_Appointment);
2- I set up CurrentView to WeekRange view in SingleWeek mode.
3- I have 2 buttons to "scroll" one week forward or backward, like this:
        private void fbPreviousWeek_Click(object sender, EventArgs e)
           fCalendar.Date = fCalendar.Date.AddDays(-7);
       private void fbNextWeek_Click(object sender, EventArgs e)
           fCalendar.Date = fCalendar.Date.AddDays(7);
4- After a few clicks on the "Next" button the application freeze and the exception is thrown. On the problematic screen, all the cells without schedule items could not be drawn.
Could you please tell me if I am doing something wrong or if this is a bug in the control?
Best regards.
Re: Calendar throws an out of memory exception.
Reply #1 - Nov 16th, 2009 at 7:46am
Try also to increase/decrease the end time of the Calendar:
      fCalendar.EndDate = fCalendar.Date.AddDays(-7);
      fCalendar.EndDate = fCalendar.Date.AddDays(7);
Otherwise, Date becomes larger than EndDate at some point and the recurrence attempts to generate occurrences in an undefined interval, which causes the exception.
jovi
Reply #2 - Nov 17th, 2009 at 3:50pm
Yes, that fixed it. Thanks Meppy!
