Normal Topic calendar reports (Read 7519 times)
mustafa
calendar reports
Aug 3rd, 2010 at 1:48pm
I am now porting my salon reservation system to Silverlight. In the planner.net control I have a reporting module but not in the Silverlight scheduling control.
1. Can you give me example of using the Silverlight MindFusion.Reporting to print the schedule report.
2. Can I get discount if will be using this reporting control only with the schedule reports.
Thanks a ton,
Mustafa Koç
Re: calendar reports
Reply #1 - Aug 3rd, 2010 at 2:57pm
The following simple report can print out a sequence of MindFusion.Scheduling items. Simply assign the Schedule.Items collection of your Calendar control as a DataContext of the report before running it.
<r:Report x:Name="plannerReport">
      <r:Page>
            <r:Label Text="Scheduling Report" AutoSize="True" FontSize="20" />
            <r:DataRange Location="0,60" Size="100%,20" AlternatingBackground="AliceBlue">
                  <r:DataRange.HeaderTemplate>
                        <DataTemplate>
                              <r:ItemContainer Size="100%,20" Background="LightSteelBlue" r:Report.FontWeight="Bold">
                                    <r:Label Location="0,0" Size="10%,20" Text="#" />
                                    <r:Label Location="10%,0" Size="40%,20" Text="Subject" />
                                    <r:Label Location="50%,0" Size="25%,20" Text="Start Time" />
                                    <r:Label Location="75%,0" Size="25%,20" Text="End Time" />
                              </r:ItemContainer>
                        </DataTemplate>
                  </r:DataRange.HeaderTemplate>
                  <r:DataRange.ItemTemplate>
                        <DataTemplate>
                              <r:ItemContainer>
                                    <r:Label Location="0,0" Size="10%,20" Text="[RangeItemCurrent()]" />
                                    <r:Label Location="10%,0" Size="40%,20" Text="[HeaderText]" />
                                    <r:Label Location="50%,0" Size="25%,20" Text="[StartTime]" TextFormat="{}{0:dddd, MMMM dd}" />
                                    <r:Label Location="75%,0" Size="25%,20" Text="[EndTime]" TextFormat="{}{0:dddd, MMMM dd}" />
                              </r:ItemContainer>
                        </DataTemplate>
                  </r:DataRange.ItemTemplate>
            </r:DataRange>
      </r:Page>
</r:Report>
The report can be vastly improved in many aspects. For example the report can be redesigned to print out resources and the individual items associated with them by using master-detail relationships.
Regarding the discount you should contact my colleagues at sales@mindfusion.eu.
Let me know if this helps.
mustafa
Reply #2 - Aug 3rd, 2010 at 3:37pm
Thanks for quick answer. My appointments are set for one custom Resource, for example tanning bed. Custom resource is named by the client. Can I display the appointment's one resource name in a column, on the same row where appointment is printed?
Best Regards,
Mustafa Koç
Reply #3 - Aug 4th, 2010 at 6:33am
This is possible through the use of an embedded DataRange object. The following code illustrates the modified report:
	<r:Page>
				<DataTemplate>
						<r:Label Location="10%,0" Size="30%,20" Text="Subject" />
						<r:Label Location="40%,0" Size="20%,20" Text="Start Time" />
						<r:Label Location="60%,0" Size="20%,20" Text="End Time" />
						<r:Label Location="80%,0" Size="20%,20" Text="Tanning bed" />
					</r:ItemContainer>
				</DataTemplate>
				<DataTemplate>
					<r:ItemContainer>
						<r:Label Location="0,0" Size="10%,20" Text="[RangeItemCurrent()]" UseDesignOrder="True" />
						<r:Label Location="10%,0" Size="30%,20" Text="[HeaderText]" UseDesignOrder="True" />
						<r:Label Location="40%,0" Size="20%,20" Text="[StartTime]" TextFormat="{}{0:dddd, MMMM dd}" UseDesignOrder="True" />
						<r:Label Location="60%,0" Size="20%,20" Text="[EndTime]" TextFormat="{}{0:dddd, MMMM dd}" UseDesignOrder="True" />
						<r:DataRange r:Name="ResourceRange" Location="80%,0" Size="20%,20" UseDesignOrder="True">
								<DataTemplate>
									<r:ItemContainer>
										<r:Label Location="0,0" Size="100%,20" Text="[Name]" />
									</r:ItemContainer>
								</DataTemplate>
						</r:DataRange>
					</r:ItemContainer>
				</DataTemplate>
		</r:DataRange>
	</r:Page>
</r:Report>
To provide details for the embedded data range, handle the QueryDetails event and use the following as content of the event handler:
var range = s as DataRange;
if (range != null)
	if (range.Name == "ResourceRange")
		Item master = args.MasterRow as Item;
		args.Details = master.Resources;
Let me know if this works.
mustafa
Reply #4 - Aug 4th, 2010 at 7:32am
It works! Thanks!
Best Regards,
Mustafa Koç
