Normal Topic Silverlight reporting binding (Read 4695 times)
Vikas Kumar
Mar 2nd, 2011 at 10:15am
The data context issue posted by me earlier is solved with the new dll provided by you. The data source is bounded fine now. But when the data source is changed the report should be updated. But it is not happening. In the documentation I found that we need to Run the report again if data source has been changed.
For doing so I have created an event in my view model and whenever data changes the event is fired and my report handler class listens this event and runs the report.
Is there any better solution to accomplish this.
Regards
Vikas
Re: Silverlight reporting binding
Reply #1 - Mar 2nd, 2011 at 11:48am
Unfortunately, re-running the report is the only currently available way to update the report when the associated data changes. The report doesn't make assumptions about the data and thus does not listen for potential change notifications.
