Normal Topic error message (Read 5782 times)
larsgj
error message
Mar 4th, 2011 at 12:47pm
Hi there
I'm trying to view a XML file with danish characters ÆØÅæøå, but gets the error: An invalid character was found in text content. If i overwrite the danish characters with X or whatever, it works fine.
Thank you in advance.
Re: error message
Reply #1 - Mar 4th, 2011 at 1:16pm
If you try to open the XML file in Internet Explorer, does it work fine?
larsgj
Re: error message
Reply #2 - Mar 4th, 2011 at 1:41pm
Just tried, and no - actually not possible to open in Internet Explorer too.
I tried Word as well and fail too. Word tells me a line an column no., and that is exactly where the first danish character "æ" is shown.
I was under the impression that various national characters were legal in XML files?  ???
Re: error message
Reply #3 - Mar 4th, 2011 at 2:12pm
Try to save the file in UTF-8 or Unicode (and also add the respective Encoding attribute to the xml tag within the file) and test again.
In addition, it appears that if you are creating the XML files with the viewer, setting the Encoding attribute will be enough to save the file in the appropriate encoding. I was able to create the following XML file within the XML viewer and it saves and loads just fine:
<?xml version="1.0" encoding="utf-8"?>
<doc>
      <element>ÆØÅæøå</element>
</doc>
larsgj
Re: error message
Reply #4 - Mar 4th, 2011 at 2:15pm
Thank you very much for your help.  Smiley
