Normal Topic Query regarding License (Read 12527 times)
Vikas Kumar
May 5th, 2011 at 8:34am
Hi Meppy,
I have been using your Mind fusion reporting tools trial version since last 2-3 months. It has fulfilled all the requirements so far.
Now We are planning to deploy the application on client' server.So want to purchase the License ,because in the current trail version, a message in red color is coming on the report page, that it is a trial version.
Will you please suggest the minimum cost of purchasing the License and also do we need to change the dll in case of the Licensed version as it may affect our code.
Please let me know the payment details and other specifications
Regards
Vikas
Re: Query regarding License
Reply #1 - May 5th, 2011 at 9:01am
You can check the various licensing options for MindFusion.Reporting for Silverlight here. The reporting component is also part of our Silverlight Pack. You can read more about it here.
Once you purchase a license you need to replace the reporting dlls referenced in your application with those contained in the licensed setup. You may need to contact us for an updated version of the dlls since the additions/corrections we made for you are not yet available in the official release.
Let me know if this helps.
Vikas Kumar
Reply #2 - May 6th, 2011 at 7:58am
Hi Meppy,
Thanks for your reply.
Once we purchase the license do we need to send the new dll to you for the up gradation.
Will there be any extra charge for the updated version of the dlls sent by you.
I remember you had also sent me the updated version of the trail dlls some times back.
Regards
Vikas
Reply #3 - May 6th, 2011 at 8:12am
There is no extra fee, simply contact my colleagues by sending an e-mail to support@mindfusion.eu and provide your order number. They will send you the most recent licensed versions of the assemblies.
Vikas Kumar
Reply #4 - Jun 6th, 2011 at 10:27am
Hi Mappy,
We have purchased the single developer lincese for reportingLite. As you had suggested , should i send the order id to support@mindfusion.eu to get the most recent licensed versions of the assemblies.
One more query I have here.
In the trail version I was using till now I got a dll which was later upgraded by you. In the licensed verison I am seeing a .msi file(windows installer).
can you please how to use this on my local machince as well as testing and production server.
Regards
Vikas
Reply #5 - Jun 6th, 2011 at 11:40am
The most recent changes to MindFusion.Reporting for Silverlight are available in version 1.1.1, which can be downloaded from our client's area here. Let me know if you have difficulties downloading it.
Vikas Kumar
Reply #6 - Jun 6th, 2011 at 12:48pm
Thanks for the reply.
I have already downloaded that version.
In our earlier conversation you had told me to upgrade the Licensed version with the new one by contacting you.
As you are saying that this already is the latest version I will install it and if any problem arises, will contact you.
Regards
Vikas
Reply #7 - Jun 6th, 2011 at 1:54pm
Yes, the version in the client's area should contain the most recent changes to the control. Please, install it, and be sure to contact me if there are any problems with it.
Vikas Kumar
Reply #8 - Jun 8th, 2011 at 7:53am
Hi Meppy,
I have installed the licensed version and have replaced the trail dll with the licensed one.
But the application is not running. It is throwing the following exception :
Set property 'MindFusion.Reporting.Silverlight.CustomReportItem.Value' threw an exception.Please provide me the latest stable version as soon as possible.
Waiting for your reply
Regards
Vikas
Reply #9 - Jun 8th, 2011 at 8:23am
Please, check your PMs.
