Normal Topic FlowChart scrolls automatically down (Read 4178 times)
foxray
May 11th, 2011 at 6:36am
I have a problem with the latest version of Flow Chart .Net. I have used the FlowChart in a very simple way. I have added ShapeNodes and have connected them by Links, nothing else. Now, sometimes it happens, when I have clicked on a node, the FlowChart scrolls down - completly automatically. When I have clicked in the FlowChart, the scrolling has stoped. Is that a known bug?
Sven
Re: FlowChart scrolls automatically down
Reply #1 - May 11th, 2011 at 7:30am
This will happen if AutoScroll is enabled and some other control captures mouse input when you click on a node near the edge. You could set AutoScroll = false to disable scrolling, or check if there is CaptureMouse called somewhere that would prevent the DiagramView from detecting the button has been released.
