Normal Topic Time-selection event issue in timetable (Read 4055 times)
nbourgogne
Jul 11th, 2011 at 7:41pm
Hi all,
I am trying out the component (ver: 2.3.1 trial) to see if it suits our application need, but I've come across a problem right off the bat: I need to create an appointment automatically when a user selects a "time cell" (or range of "time cells") in the timetable view.
This doesn't seem possible, at least I haven't seen a property or event that would be a trigger for an item creation Embarrassed.
The only way that seems possible is from the "Selection" object's "Changed" event, but changing the selection triggers multiple (tens!) of "Selection.Changed" events, while the selection is still being modified.
The need to type after having selected the time is a deal breaker for my client, so I hope there is an (elegant) way to do this!
Thanks!
Re: Time-selection event issue in timetable
Reply #1 - Jul 11th, 2011 at 8:42pm
Set Calendar.EnableDragCreate=true.
nbourgogne
Reply #2 - Jul 12th, 2011 at 3:08am
Thanks Stoyan,
No I fell dumb Wink
