Normal Topic Binding Errors when {Binding XXX} used (Read 4062 times)
Tim99
Oct 14th, 2011 at 10:15am
When you use a {Binding XXX} to specify a content or as a DataSource a BindingExpression path error is reported in the projects Output window.
This can be avoided by using [FieldName] rather than the {Binding FieldName} but you cannot do this for a DataSource.
When producing loger reports you get multiple binding errors for each row which take a lot of time to produce before the report is visible.
Is there a way of specifying the DataSource without getting these Binding Errors?
Thanks again for your help.
Re: Binding Errors when {Binding XXX} used
Reply #1 - Oct 17th, 2011 at 2:27pm
The current problem we are facing is that bindings established when the DataContext is still not set do not work later, when the DataContext is set. Assigning a special object as a DataContext seems to resolve this issue, but causes all bindings to give the error in question because they refer to properties which do not exist. A temporary solution for turning these errors off is the following: go to the Options dialog in Visual Studio (Tools -> Options menu). In the dialog select Debugging -> Output Window and set Data Binding to Off.
