Normal Topic Charting for WPF, v1.3 (Read 2291 times)
Dec 8th, 2011 at 3:26pm
We have released version 1.3 of MindFusion.Charting for WPF. It contains the following new features:
Zoom
Interactive zoom support is now available in all types of bar and line charts. Set the Behavior property to ZoomChart to let users interactively select a range to zoom into. You can zoom out to a previous range one step at a time by calling ZoomOut. Use ResetZoom to restore the chart to its original state.
DateTime values
You can set the XData, YData or Y2Data of the LineSeries or BarSeries instances to DateTime values. Set the ValueFormat property of the respective AxisSettings object to ValueFormat.DateTime and specify appropriate DateTime values as start and end of the axis. You can find details on how to use DateTime values with the control in the DateTime Values section of this reference.
~ you can set the start angle in pie charts with StartAngle
~ labels at the chart axis can be rotated with the LabelRotationAngle property
~ improved space calculations in line and bar charts with mixed data.
https://mindfusion.eu/WpfChartTrial.zip
