Normal Topic problem with serialize (Read 5093 times)
jackhuclan
Jan 6th, 2012 at 9:23am
Diagram.SaveToXml() or SaveToString() twice will raised errors. The diagramNode tag binding an object seems like
Class Sample:INotifyPropertyChanged
private string _name;
public string Name
get{return _name;}
set
_name=value;
OnPropertyChanged("Name");
public event PropertyChangedEventHandler PropertyChanged;
private void OnPropertyChanged(string propertyName)
if(PropertyChanged!=null)
PropertyChanged(this,new PropertyChangedEventArgs(propertyName);
when call the diagram save* method ,will report error: Type 'System.ComponentModel.PropertyChangedEventManger ' in Assembly 'WindowsBase.Version=4.0.0.0,cultere=......' is not marked as serializable.
please  help...,thanks
Re: problem with serialize
Reply #1 - Jan 6th, 2012 at 11:22am
The classes whose objects you are using as Tag values must be serializable. Mark them with the [Serializable] attribute, and implement the ISerializable interface if some of their fields are not serializable (such as PropertyChangedEventManger you mentioned causing the exception).
Alternatively, handle the SerializeTag event to save the tags as Xml elements; see the SiteMap sample project for an example.
jackhuclan
Reply #2 - Jan 9th, 2012 at 3:22am
It's very useful ,thanks
