MindFusion.Reporting for WinForms 2.0 has been released. It adds the following new features:
ReportEditor ControlA new ReportEditor control is now available. The report can be embedded in any application to provide the ability to create, save, open, preview and print reports. The editor UI consists of a designer area, a property grid, a toolbox, and a preview panel. The report provides features, such as clipboard operations, undo and redo, the ability to register external data sources for use inside the editor, simplified serialization, and more.
XML SerializationThe reports can now be serialized and deserialized to and from XML files through the means of the SaveToXml and LoadFromXml methods respectively.
Report ParametersParameters can now be added to a report through the new Parameters collection of the Report class. The parameters provide name, description and value and can be of any type, including expression.
Improved Expression EditorThe built-in Expression Editor has been improved. It now provides direct access to the built-in expression functions as well as the available keywords, operators, report parameters and table fields.
clients area on our site.
https://mindfusion.eu/ReportingTrial.zipEnjoy!
