We have released version 1.4 of MindFusion.Charting for WPF. It contains the following new features:
Interactive data modificationUsers can drag data points in line charts or the top of a bar in bar charts to change the data value. This is done by setting the Behavior property to Behavior.AllowXDrag or Behavior.AllowYDrag. The Behavior enumeration now allows bitwise combination and you can enable dragging along both X and Y axis.
Second X-axisThe X2AxisSettings allows you to define a second X-axis. Data for series that are bound to X2 is set with X2Data. X2Labels sets custom labels for the X2-axis. Data binding is available through the X2DataPath and X2LabelPath properties.
Miscellaneous~ Data binding properties for the second Y-axis are available: Y2DataPath and Y2LabelPath.
~ Chart series can have dashed strokes or outlines with the StrokeDashArray, StrokeDashCap, StrokeDashOffset, StrokeEndLineCap, StrokeLineJoin, StrokeMiterLimit and StrokeStartLineCap properties.
~ The new LabelStroke property sets the brush for drawing labels at chart axes. The TitleStroke defines the brush for drawing the title label. TitleRotationAngle defines the rotation angle of the title label in horizontal axes.
clients area on our site.
https://mindfusion.eu/WpfChartTrial.zipEnjoy!
