Normal Topic Jpg or png inside a ShapeListBox (Read 4088 times)
Andy (CyT)
Aug 30th, 2012 at 8:04pm
Dear Moderator,
Using this configuration:
Diagramming for ASP.NET 4.2
Java Applet mode
Using this controls
<ndiag:ShapeListBox />
<ndiag:DiagramView />
<ndiag:Overview />
With the former configuration, I understand the only way I can fulfill the ShapeListBox in order to drag & drop over the
DiagramView is using the external xml file with the shapes on it.
The question is, if there is any way to fill the ShapeListBox with images such as .jpg or .png ?
Best regards, Andy.
Re: Jpg or png inside a ShapeListBox
Reply #1 - Aug 31st, 2012 at 7:03am
You could assign images to shapes in the shape library:
  <shape id="newShape1" fill-mode="Winding" display-name="">
    <outline>...</outline>
    <decorations />
    <shape-decorations />
    <image x="0" y="0" width="100" height="100" src="test.jpg" />
    <enable-outline>True</enable-outline>
  </shape>
