Normal Topic Float values in bar chart (Read 8819 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Sep 6th, 2012 at 8:58am
Dear Stoyan,
               i am using bar chart(v3.4). when i am using the integer values it is working fine.but when i am trying for the float values it displaying the value wrong. kindly help
if you want something then go and grab it
Re: Float values in bar chart
Reply #1 - Sep 6th, 2012 at 10:13am
I can't see an problem with float values. If you are assigning them from the property grid, are you using "." as the fraction separator and "," to separate the values in the series?
madhan1
FROM EVERY ONE ..
Reply #2 - Sep 6th, 2012 at 11:26am
Dear stoyan,
     here the following code i am using
double[] pw_median = new double[count];
string[] pw_name = new string[count];
for (int i = 0; i < count; i++)
pw_median[i]=Convert.ToDouble(ds.Tables[0].Rows[i]["Median_HB"]);
pw_name[i] = (ds.Tables[0].Rows[i]["phc_name"].ToString());
BarChart7.XLabels = pw_name;
//double[] data ={ 10.4,10.6,10.4 }; now
BarChart7.Data.Clear();
BarChart7.Data = pw_median;
BarChart7.TitleText = "HB Median ";
while we are binding the data we receive the values of ( 10.4,10.6,10.4)
Reply #3 - Sep 6th, 2012 at 12:53pm
Apparently the control decides you are giving it date values... Set barChart1.YAxisSettings.DataFormat = DataFormat.Number and it should work better.
madhan1
FROM EVERY ONE ..
Reply #4 - Sep 7th, 2012 at 8:05am
Thanks stoyan
it works fine
