Normal Topic labels display in line chart (Read 18501 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Sep 20th, 2012 at 2:56pm
Dear stoyan,
i don't want to display the Y Axis & X Axis labels in line chart. kindly help
if you want something then go and grab it
Re: labels display in line chart
Reply #1 - Sep 20th, 2012 at 4:16pm
The following code hides the labels at the X-axis. You might have to set AxisLength explicitly, because it is usually calculated from the label widths and the axis might get too short without labels. You can also hide the axis title by setting it to empty string:
LineChart1.XAxisSettings.LabelType = MindFusion.Charting.AxisLabelType.Empty;
LineChart1.XAxisSettings.AxisLength = 300;
LineChart1.XAxisSettings.TitleLabel = "";
madhan1
FROM EVERY ONE ..
Reply #2 - Sep 20th, 2012 at 6:27pm
thanks stoyan,
         but some time i will get empty data. at that point it is throwing error.
Note : i cannot set the control to visiable=false;
Reply #3 - Sep 21st, 2012 at 8:36am
What do you mean by getting empty data, and what exception are you getting? Calling Clear on the XData and YData collections works fine in my test project.
madhan1
FROM EVERY ONE ..
Reply #4 - Sep 21st, 2012 at 9:19am
Sorry stoyan, i didn't explained you. some time i don't have data from the database. at that time i am receiving some errors.
Reply #5 - Sep 21st, 2012 at 12:08pm
Are you assigning data as shown in this post?
http://mindfusion.eu/Forum/YaBB.pl?num=1346921892
What's the value of the pw_median array in such case?
madhan1
FROM EVERY ONE ..
Reply #6 - Sep 24th, 2012 at 4:25am
sorry stoyan,
            my array have null data.(some time i don't have data for some dates.) i that time i am reeving error
Reply #7 - Sep 24th, 2012 at 5:47am
You will have to replace nulls with actual dates for the time being. We'll add some support for null values for next release.
madhan1
FROM EVERY ONE ..
Reply #8 - Sep 24th, 2012 at 9:14am
Thanks stoyan
