Normal Topic Timetable, Adding days problem (Read 4216 times)
Joona
Nov 7th, 2012 at 7:46pm
For some reason when i try to add days to datecollection in timetable settings, it wont work. For example i add 7 days to date collection. It only takes last one of them. Heres my code for doing it. Wheres the problem?
        For isa As Integer = 0 To Calendar1.TimetableSettings.Dates.Count - 1
            Calendar1.TimetableSettings.Dates.RemoveAt(isa)
        Next
        Dim dtNow As Date = Date.Now.Date
        Calendar1.TimetableSettings.Dates.Capacity = 10
        Dim nowdayofweek As Integer = dtNow.DayOfWeek
        Dim weekStartDate, weekEndDate As Date
        weekStartDate = DateAdd("d", 0 - dtNow.DayOfWeek,    dtNow)
        weekEndDate = DateAdd("d", 6 - dtNow.DayOfWeek, dtNow)
        Dim loopDate As New TimetableDate
        loopDate.Value = weekStartDate
        Dim index As Integer = 0
This is the code that should add dates to collection. other code is just to get start and end date from current week so i can add all days of this week to collection.
        While loopDate.Value <= weekEndDate
            Calendar1.TimetableSettings.Dates.Add(loopDate)
            loopDate.Value = loopDate.Value.AddDays(1)
        End While
Lyubo
MindFusion team
Re: Timetable, Adding days problem
Reply #1 - Nov 8th, 2012 at 7:01am
The code is not working because TimetableDate is a reference type and when you just modify the Value property of loopDate and try to re-add that instance to the Dates collection, it's already there, so Add actually exits without adding the item. You have to create new instances of the TimetableDate class and add those to the collection. Your snippet can be modified to something like this:
Calendar1.TimetableSettings.Dates.Clear()
While True
  If weekStartDate > weekEndDate Then
    Exit While
  End If
  ' Creates a new instance of the TimetableDate class and
  ' adds it to the Dates collection
  Calendar1.TimetableSettings.Dates.Add(New TimetableDate(weekStartDate))
  weekStartDate += TimeSpan.FromDays(1)
End While
Lyubo
Joona
Reply #2 - Nov 9th, 2012 at 7:52am
Well that solved my problem, Thank you very much Smiley
