Hot Topic (More than 10 Replies) convert calendar into pdf (Read 11825 times)
SLUser
Dec 9th, 2012 at 9:35pm
What would be the best way to convert (print, export,..) a calendar into a pdf file ? (Preferably done on the webserver in a standard .NET / non silverlight environment).
Re: convert calendar into pdf
Reply #1 - Dec 10th, 2012 at 9:05am
Currently only the reporting component of the WinForms version of the control supports exporting to PDF. You can preview a sample exported PDF attached to this post. If this suits your needs we can port the reporting functionality to the ASP.NET version so that it can be done on server-side.
sample.pdf (Attachment deleted)
SLUser
Reply #2 - Dec 10th, 2012 at 8:20pm
This report is a textual representation. Is there also a graphical representation of the calendar in pdf possible ?
Reply #3 - Dec 11th, 2012 at 12:58pm
We have implemented a WYSIWYG PDF export in the WinForms version of the Scheduling component. To export to a PDF file you can use the WinForms Calendar control on the server-side of a Silverlight application, as illustrated by the sample below:
https://mindfusion.eu/_samples/_sample_pdfexport.zip
Note that the exporting is heavily dependent on the view settings. The sample does not transfer any view properties from the client to the server (except Width, Height, CurrentView, and Theme). If you need to specify additional view settings on the client, you have to either transfer those as well or hardcode them in the server-side calendar.
Sample result of the exporting can be observed below:
http://mindfusion.eu/_samples/sample2.pdf
Let me know if this helps.
SLUser
Reply #4 - Dec 14th, 2012 at 8:24am
Thanks, this is already a big step in the solution for my problem.
One last question. I was already using PdfSharp for the creation of pdf docs on the webserver. Is there a way to merge the pdf calendar into a pdfsharp doc ?
Or perhaps I would better export the calendar to another format (bitmap,....) that I can use in pdf sharp ?
Reply #5 - Dec 14th, 2012 at 9:25am
It appears that PDFsharp supports PDF merging, according to this link. Additional information on how it is done can be found here.
SLUser
Reply #6 - Dec 18th, 2012 at 9:31pm
OK, I am trying to use your example in my test project.
However on the Silverlight client I had defined an ItemPresenter for an Appointment derived class so that specific appointments had a custom style.
The ItemPresenter refered to a style defined in the App.XAML file.
How can I do this on the server side ? (where there is only Winforms support and no XAML ?)
Thanks again.
Reply #7 - Dec 19th, 2012 at 6:22am
You can use custom drawing (or custom item viewers) in order to resemble the custom item presenters on the client. I may help you with the specifics if you provide me with the item presenters' style.
SLUser
Reply #8 - Dec 19th, 2012 at 7:20pm
OK. I've found an example on creating an ItemViewer and implementing the Draw function. That seems to do the trick indeed !
SLUser
Reply #9 - Mar 2nd, 2013 at 11:21am
I'm still using this winforms version on the backend of my silverlight site, however I get an exception when saving the schedule to XML.
NullreferenceException in the WriteCustomBrushes function.
I don't know about custombrushes, what should i do to prevent this exception ?
Reply #10 - Mar 3rd, 2013 at 11:25am
I am not able to reproduce the exception with this version. Try using the latest WinForms build below:
https://mindfusion.eu/_temp/MindFusion.Scheduling.5.4.4.trial2.zip
If the exception still happens, please, provide me with the full stack trace and, if possible, the XML of the calendar serialized on the client side.
SLUser
Reply #11 - Mar 3rd, 2013 at 8:42pm
I also get the exption with this version:
   bij MindFusion.Scheduling.XmlSerializationContext.WriteCustomBrushes(CustomBrushes customBrushes, String elementName, XmlElement parentElement)
   bij MindFusion.Scheduling.Resource.SaveTo(XmlElement element, XmlSerializationContext context)
   bij Trainers.Web.Calendars.Trainer.SaveTo(XmlElement element, XmlSerializationContext context) in C:\trainers\Trainers\Trainers.Web\Calendars\Trainer.cs:regel 23
   bij MindFusion.Scheduling.XmlSerializationContext.xe8bc3e7f9bd73a52(Resource x41c4b132ee719a30, XmlElement x1ea18269223b2a9c, String x121383aa64985888)
   bij MindFusion.Scheduling.Schedule.SaveToXml(XmlDocument document)
   bij Trainers.Web.Services.Service1.SyncWithGoogleCal(_vwCalendar cal) in C:\trainers\Trainers\Trainers.Web\Services\Service1.asmx.cs:regel 820
   bij Trainers.Web.Services.Service1.GetCalendarData(Guid id) in C:\trainers\Trainers\Trainers.Web\Services\Service1.asmx.cs:regel 766
I used a custom resource class (Trainer, inherits from resource), in the SaveTo(Xml) of the base (resource class) is where the exception occurs.
Reply #12 - Mar 4th, 2013 at 8:07am
Please, try again with this version:
https://mindfusion.eu/_temp/MindFusion.Scheduling.5.4.4.trial3.zip
SLUser
Reply #13 - Mar 4th, 2013 at 5:17pm
OK Thanks, the issue seems to solved !
