Normal Topic Switching between month/weekview and dayview takes long (Read 3730 times)
SLUser
Dec 17th, 2012 at 9:36pm
It takes about 4 to 5 seconds before the calendar show the day view even with an empty calendar. Is this normal ?
Can anything be done to speed this up ?
Re: Switching between month/weekview and dayview takes long
Reply #1 - Dec 18th, 2012 at 8:21am
You can speed up switching between views by using separate Calendar controls for each view, then just toggle the visibility of the controls in order to display the one that you need. It is important to assign the same Schedule object to all controls so they are automatically synchronized when the schedule is changed.
Let me know if this helps.
SLUser
Reply #2 - Dec 19th, 2012 at 6:43pm
OK. This seems to work and is indeed a lot faster when switching (only the first time the timetable is shown is still slow).
Thanks.
