Normal Topic Could not load file or assembly (Read 5474 times)
Tomy
Dec 22nd, 2012 at 7:10pm
I have two warnings... can you help me?
Best regards
Tomy
1.
Warning      4      C:\ProjektVB\VS2010\touristsoftCH\touristsoftCH\Accommodation\TravelCalendar.asp
x: ASP.NET runtime error: Could not load file or assembly 'MindFusion.Scheduling.WebForms, Version=3.0.0.0, Culture=neutral, PublicKeyToken=1f8404677be623be' or one of its dependencies. Parameter not correct. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))      C:\ProjektiVB\VS2010\touristsoftCH\touristsoftCH\Accommodation\TravelCalendar.as
px      1      1      touristsoftCH
2.
Warning      3      Unrecognized tag prefix or device filter 'MindFusion'.      C:\ProjektVB\VS2010\touristsoftCH\touristsoftCH\Accommodation\TravelCalendar.asp
x      68      2      touristsoftCH
Lyubo
MindFusion team
Re: Could not load file or assembly
Reply #1 - Jan 2nd, 2013 at 7:47am
Are you able to compile and run the project without errors? If it runs, does the component work as expected?
Lyubo
Tomy
Reply #2 - Jan 9th, 2013 at 9:32am
Hi Lyubo,
there is no problem by project building and executing... everything works fine... I just ask about this warning, maybe you have more information...
Thanks anyway.
Tomy
Lyubo
MindFusion team
Reply #3 - Jan 9th, 2013 at 12:48pm
Hi Tomy,
Do the warnings disappear after some time or are they always present? Maybe the Visual Studio designer doesn't find the dll-s right away.
You could try rebuilding the project or if that doesn't help - manually deleting the bin and obj folders and building again.
Lyubo
