Normal Topic Windows 8 copy and paste problem (Read 3474 times)
Bob
Feb 19th, 2013 at 6:15pm
When I try to copy from XML viewer into any other type of document it will not paste. It does not matter if it is a line, a node, or the whole file.
Any suggestions.  Other programs copy and paste with no problem.
Re: Windows 8 copy and paste problem
Reply #1 - Feb 20th, 2013 at 9:06am
At this time XML Viewer doesn't copy to the system clipboard, but copy/paste only replicates nodes in the viewer's tree representation of the XML file. You can still copy data to the system clipboard as text from the View -> XML Source window.
