Normal Topic height self-adaption (Read 7496 times)
luolishuang
Feb 22nd, 2013 at 9:06am
How to make the r:Label automatically adjust the height based on the current content?
Re: height self-adaption
Reply #1 - Feb 22nd, 2013 at 9:27am
This is not currently possible. We have recently added a similar feature to the WinForms version of the component and will implement it in the WPF version as well. I will get back to you with a preview as soon as it is available.
luolishuang
Reply #2 - Feb 25th, 2013 at 1:09am
thanks.
I look forward to it.
Reply #3 - Feb 26th, 2013 at 3:05pm
Hi again,
We have improved the support for auto-sizing labels in MindFusion.Reporting for WPF. You can download a sample illustrating how to create reports similar to the one in your image from the link below (the updated reporting assemblies are located in the bin\debug folder of the sample):
https://mindfusion.eu/_samples/_sample_ListBinding.zip
Let me know if this helps.
luolishuang
Reply #4 - Feb 27th, 2013 at 1:45am
Meppy wrote on Feb 26th, 2013 at 3:05pm:
Hi again,
Meppy,it really help me.
Thank you very much!
luolishuang
Reply #5 - Feb 27th, 2013 at 2:16am
<r:ItemContainer CanOverflow="False">
i try to remove the CanOverflow="False",it seemed to be working very well
i don't know this attribution here has other intention?
Reply #6 - Feb 27th, 2013 at 7:11am
The CanOverflow property does not have any effect if the report fits on a single page. The meaning of this property is to prevent (when set to false) splitting of the DataRange contents over two pages when paginating the report. If this property is set to false and an instance of the DataRange does not fit completely on a page, the entire instance is moved on the next page. If this property is true (the default), portion of the DataRange is fit in the remaining space on the current page and the remaining DataRange content is moved on the next page.
