Normal Topic How to add container(like Grid) in r:datarange (Read 7250 times)
luolishuang
Feb 22nd, 2013 at 9:13am
Re: How to add container(like Grid) in r:datarange
Reply #1 - Feb 22nd, 2013 at 9:38am
You can use any WPF FrameworkElement in a report through the CustomReportItem object. The following code illustrates how to embed a Grid panel:
<r:CustomReportItem Location="5,5" Size="150,40">
	<r:CustomReportItem.Template>
		<DataTemplate>
			<Grid>
				<Grid.ColumnDefinitions>
					<ColumnDefinition />
				</Grid.ColumnDefinitions>
				<Grid.RowDefinitions>
					<RowDefinition />
					<RowDefinition />
					<RowDefinition />
				</Grid.RowDefinitions>
				<Border Background="#10000000">
					<TextBlock Text="Header 1" />
				</Border>
				<Border Background="#10000000" Grid.Column="1">
					<TextBlock Text="Header 2" />
				</Border>
				<TextBlock Text="item 1" Grid.Row="1" />
				<TextBlock Text="item 2" Grid.Row="1" Grid.Column="1" />
				<TextBlock Text="item 3" Grid.Row="2" />
				<TextBlock Text="item 4" Grid.Row="2" Grid.Column="1" />
			</Grid>
		</DataTemplate>
	</r:CustomReportItem.Template>
</r:CustomReportItem>
luolishuang
Reply #2 - Feb 25th, 2013 at 12:58am
Only in CustomReportItem? Could it be put in DataRange?
Thanks for you reply!
Reply #3 - Feb 25th, 2013 at 6:49am
You can add the CustomReportItem containing the Grid to the DataRange object:
<r:DataRange Size="100%,50" DataSource="...">
	<r:DataRange.ItemTemplate>
		<DataTemplate>
			<r:ItemContainer>
				<r:CustomReportItem>...</r:CustomReportItem>
			<r:ItemContainer>
		</DataTemplate>
	</r:DataRange.ItemTemplate>
</r:DataRange>
You can also check the CustomReportItems sample installed with the product. It illustrates how to add a WPF Grid object (containing a Border and a TextBlock) to the report.
luolishuang
Reply #4 - Feb 25th, 2013 at 7:16am
Thanks for help.
luolishuang
Reply #5 - Feb 27th, 2013 at 2:25am
Meppy,
Can the report control (like r:Label) be put in Grid?
Reply #6 - Feb 27th, 2013 at 7:20am
Report elements are designed to be used only inside reports, parented in other report elements, or as root elements inside data templates. Even though technically you are able to put report elements (like Label) inside a WPF grid, this really would not yield the expected result.
