Normal Topic persist data into database (Read 4857 times)
ricardo
Mar 14th, 2013 at 2:00pm
Hi
what is the best way to persist the data into a database?
can you provide a sample?
Re: persist data into database
Reply #1 - Mar 14th, 2013 at 3:45pm
The simplest way would be to serialize the entire calendar as a string (using the Schedule.SaveTo method) and then write this string to the database. To serialize the calendar as a string use the following approach:
using (MemoryStream s = new MemoryStream())
	calendar.Schedule.SaveTo(s);
	s.Flush();
	s.Seek(0, SeekOrigin.Begin);
	StreamReader reader = new StreamReader(s);
	string xml = reader.ReadToEnd();
	// Write 'xml' to the database
ricardo
Reply #2 - Mar 14th, 2013 at 5:51pm
three question more:
1) how to load it?
2) do you have any idea if the calendar is used very offen how much big will be the xml? this is why we where thinking in sql.
3) Can we restrict the amount of information to be saved (lets says only from 1 month ago and further)
Lyubo
MindFusion team
Reply #3 - Mar 15th, 2013 at 10:39am
1) To load the schedule from string you can use something like this (you may need to use different encoding):
// Read the 'xml' string from database...
using (MemoryStream s = new MemoryStream(System.Text.Encoding.UTF8.GetBytes(xml))
    calendar.Schedule.LoadFrom(s);
2) An Appointment object in the calendar results to about 1K uncompressed xml text when saved. You can decrease the size by compressing the stream before saving with the help of the DeflateStream class (http://msdn.microsoft.com/en-us/library/system.io.compression.deflatestream.aspx).
3) The easiest way to do this is to save the existing Schedule to a Stream, load the stream into another Schedule object, modify the Items collection to remove the older items, and then save the modified schedule. Something like:
private Schedule CloneSchedule(Schedule original)
    Schedule clone = new Schedule();
        original.SaveTo(s);
        s.Flush();
        clone.LoadFrom(s);
        for (int i = clone.Items.Count - 1; i >= 0; i--)
            Appointment app = clone.Items[i] as Appointment;
            if (app.StartTime < DateTime.Today.AddMonths(-1))
                clone.Items.Remove(app);
    return clone;
Note that the above approach doesn't consider recurrent items.
Lyubo
