Normal Topic meetings at same time or part of the same time (Read 3168 times)
ricardo
Mar 26th, 2013 at 11:38am
is it possible to avoid the creation of "collisions appointments" ? is there any attribute for it? or I have to search one by one?
Re: meetings at same time or part of the same time
Reply #1 - Mar 26th, 2013 at 12:25pm
You need to handle the ItemCreating (and ItemModifying if you need to prevent collisions through item modifications as well) event and cancel the item creation (or modification) if the target time interval is already occupied. Here is some sample code for both event handlers:
private void calendar_ItemModifying(object sender, ItemModifyConfirmEventArgs e)
	var items = calendar.Schedule.GetAllItems(e.Item.StartTime, e.Item.EndTime.AddTicks(-1));
	if (items.Contains(e.Item))
		items.Remove(e.Item);
	e.Confirm = items.Count == 0;
private void calendar_ItemCreating(object sender, ItemConfirmEventArgs e)
I hope this helps.
