Hot Topic (More than 10 Replies) The empty DataRange can NOT be exported to PDF (Read 16753 times)
luolishuang
May 14th, 2013 at 9:44am
any solution??
Re: The empty DataRange can NOT be exported to PDF
Reply #1 - May 14th, 2013 at 11:09am
Currently empty data ranges are not displayed in reports. You can set DataRange.Repeat to 1 for the data range to force it to have one instance.
Let me know if this helps.
luolishuang
Reply #2 - May 15th, 2013 at 3:25am
but I wanna to control the datarange to display or not by condition.
any solution?
Reply #3 - May 15th, 2013 at 5:33am
Try setting DataRange.Repeat to 1 for the empty data ranges that you want to be visible. Make sure that DataRange.DataSource is set to null in this case. You can also set Repeat in the QueryDetails event handler for nested data ranges. In this case set QueryDetailsEventArgs.Details to null.
luolishuang
Reply #4 - May 15th, 2013 at 6:43am
Meppy wrote on May 15th, 2013 at 5:33am:
This still display the DataRange, but I wanna to control the DataRange invisible.
any solution?
Reply #5 - May 15th, 2013 at 8:12am
Can you provide me with a sample with your report and specify which data ranges in this report you want to show or hide?
luolishuang
Reply #6 - May 15th, 2013 at 9:01am
Meppy wrote on May 15th, 2013 at 8:12am:
Hi, the xaml sample code below:
Code (HTML)
            <r:DataRange DataSource="{Binding QuestionTable}" Size="100%,100">
                <r:DataRange.ItemTemplate >
                    <DataTemplate >
                        <r:ItemContainer >
                            <r:DataRange  Name="AnswerList" Location="0%,60" Size="100%,20">
                                <r:DataRange.ItemTemplate>
                                    <DataTemplate>
                                        <r:ItemContainer>
                                            <r:Label Location="0%,0" Size="30%,20"  Background="{Binding QTitle}" BorderBrush="#ACE6EF"  BorderThickness="1,0,1,1" Padding="5,0,0,0" Text="[SID]" />
                                            <r:Label Location="30%,0" Size="30%,20"  Background="{Binding QTitle}" BorderBrush="#ACE6EF" BorderThickness="0,0,1,1" Padding="5,0,0,0" Text="[SName]"/>
                                            <r:Label Location="60%,0" Size="40%,20"  Background="{Binding QTitle}" BorderBrush="#ACE6EF" BorderThickness="0,0,1,1" Padding="5,0,0,0" Text="[SReply]"/>
                                        </r:ItemContainer>
                                    </DataTemplate>
                                </r:DataRange.ItemTemplate>
                            </r:DataRange>
                            <r:DataRange  Name="EliminationList" Location="0%,100" Size="100%,20" >
                                <r:DataRange.HeaderTemplate>
                                    <DataTemplate>
                                        <r:ItemContainer Size="100%,20">
                                            <!--EliminationList-->
                                            <r:Label  Location="0%,0" Size="100%,20" Background="#B8DAE3" BorderBrush="#ACE6EF" BorderThickness="1,0,0,0" Padding="5,0,0,0" Text="Elimination List" FontSize="14" />
                                        </r:ItemContainer>
                                    </DataTemplate>
                                </r:DataRange.HeaderTemplate>
                                    <DataTemplate>
                                        <r:ItemContainer>
                                            <r:Label Location="0%,0" Size="100%,20" BorderBrush="#ACE6EF"  BorderThickness="1,1,1,0" Padding="5,0,0,0" Text="[SName]"/>
                                        </r:ItemContainer>
                                    </DataTemplate>
                            </r:DataRange>
                        </r:ItemContainer>
                    </DataTemplate>
            </r:DataRange>
I wanna to control "EliminationList" DataRange to show or hide.
thx..
Reply #7 - May 15th, 2013 at 9:44am
You can handle the QueryDetails event of the report, inspect the sender's name and if it is "EliminationList", do one of the following depending on whether you want to show or hide the range:
  • To hide the range, simply assign an empty IEnumerable (for example new object[] {}) to QueryDetailsEventArgs.Details. This will indicate that the range is empty.
  • To show the range, set Details to null and DataRange.Repeat to 1.
luolishuang
Reply #8 - May 16th, 2013 at 12:58am
Meppy wrote on May 15th, 2013 at 9:44am:
Yeah, it will hide the DataRange, but this will throw exception when exporting to PDF
Reply #9 - May 16th, 2013 at 7:38am
I have sent you an e-mail with an updated version that should address this problem.
luolishuang
Reply #10 - May 17th, 2013 at 1:11am
Meppy wrote on May 16th, 2013 at 7:38am:
Thanks for your great help, the problem is solved,
but there is still little problem, when the "EliminationList" DataRange is hidden, the area is still exist, like image below
The blank area can be removed?
Reply #11 - May 17th, 2013 at 9:40am
You can try setting the height of the DataRange in question to 0 (that is, set Size to "W,0" where W is your current value for width). If the range has any content, it will be resized accordingly so that the content fits; if it is empty, it should take no space. However, the header of the data range (if any) will still be accounted for.
luolishuang
Reply #12 - May 20th, 2013 at 1:56am
I set my "AnswerList" and "EliminationList" DataRange size's height to 0, but seem still the same effect.
Reply #13 - May 20th, 2013 at 5:41am
Can you please attach the full XAML of your report?
luolishuang
Reply #14 - May 20th, 2013 at 6:59am
Meppy wrote on May 20th, 2013 at 5:41am:
This is my full XAML report below,
thanks.
Code (HTML)
<ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:r="http://mindfusion.eu/reporting/wpf">
    <r:Report x:Key="EliminationReport" FontFamily="Arial" FontSize="12">
        <r:Page >
            <!-- Page Content-->
                    <DataTemplate >
                        <r:ItemContainer >
                            <!--Note Info-->
                            <r:Label Location="0,0" Size="100%,20" Background="#EAA41E" BorderBrush="#ACE6EF" BorderThickness="1,1,1,0" Text="(Note:__ means No Answer,_N means you got the chance to answer but did not answer in Rush Quiz Mode)" FontSize="14" />
                            <r:Label Location="0%,20" Size="100%,20" Background="#B8DAE3" Text="[QTitle]" BorderBrush="#ACE6EF" BorderThickness="1,1,1,0" FontSize="14"/>
                            <r:Label Location="0%,40" Size="30%,20" Background="#F8F488" BorderBrush="#ACE6EF"  BorderThickness="1,0,1,1" Padding="5,0,0,0" Text="Participant ID" FontSize="14" />
                            <r:Label Location="30%,40" Size="30%,20" Background="#F8F488" BorderBrush="#ACE6EF"  BorderThickness="0,0,1,1" Padding="5,0,0,0" Text="Full Name" FontSize="14" />
                            <r:Label Location="60%,40" Size="40%,20" Background="#F8F488" BorderBrush="#ACE6EF"  BorderThickness="0,0,1,1" Padding="5,0,0,0" Text="Response" FontSize="14" />
                            <r:DataRange  Name="AnswerList" Location="0%,60" Size="100%,0">
                                    <DataTemplate>
                                        <r:ItemContainer>
                                        </r:ItemContainer>
                                    </DataTemplate>
                            </r:DataRange>
                            <r:DataRange  Name="EliminationList" Size="100%,0" >
                                    <DataTemplate>
                                        </r:ItemContainer>
                                    </DataTemplate>
                                    <DataTemplate>
                                        <r:ItemContainer>
                                        </r:ItemContainer>
                                    </DataTemplate>
                            </r:DataRange>
                        </r:ItemContainer>
                    </DataTemplate>
            </r:DataRange>
            <!-- Page Footer -->
            <r:Page.FooterTemplate>
                <DataTemplate>
                    <r:ItemContainer Size="100%,30">
                        <r:Label Size="100%,30" Text="[PageCurrent()]/[PageCount()]" HorizontalAlignment="Center" VerticalAlignment="Center" />
                    </r:ItemContainer>
                </DataTemplate>
            </r:Page.FooterTemplate>
        </r:Page>
    </r:Report>
</ResourceDictionary>
