Hot Topic (More than 10 Replies) the internal label position(Reporting.pieChart) (Read 11036 times)
cfn_zzq
Jun 7th, 2013 at 8:00am
How to set the internal label into the pie chart, and how to set the percentage with decimal point?
Re: the internal label position(Reporting.pieChart)
Reply #1 - Jun 7th, 2013 at 10:33am
Have a look at this version:
https://mindfusion.eu/_temp/MindFusion.Reporting.Wpf.trial.zip
The PieChart class exposes two new properties that enable you to control the position of the chart labels, namely InnerLabelLocation and OuterLabelOffset.
InnerLabelLocation is a value in the interval [0..1] which specifies the relative location of the inner labels along the radius length. The default is 0.85, which positions the inner labels just outside the chart. You can try with smaller values, for example 0.5. OuterLabelOffset is an absolute value specifying the offset of the outer labels.
Specifying formatting for the displayed label values is currently not possible, but something we will consider adding in the next version of the control.
luolishuang
Reply #2 - Jun 8th, 2013 at 1:37am
Meppy wrote on Jun 7th, 2013 at 10:33am:
Hi Meppy,
This is a colleague of mine, Can take me a newest official version of dlls?
Best Regards,
Luo Lishuang
luolishuang
Reply #3 - Jun 9th, 2013 at 1:10am
Hi Meppy,
The PieChart in report could NOT be exported to Excel file?
any solution?
Best Regards,
Luo Lishuang
luolishuang
Reply #4 - Jun 9th, 2013 at 1:51am
also,The PieChart exported to PDF file has a little problem, like image below, why the image in PDF file can NOT be consistent at source image?
Reply #5 - Jun 9th, 2013 at 7:59am
We were able to reproduce the bug with the PDF export and will look into it. Regarding exporting charts to excel, this is currently not supported, but we have plans to extend our excel exporter in the near (even though not immediate) future so you may stay tuned.
cfn_zzq
Reply #6 - Jun 17th, 2013 at 2:56am
In the pieChart,the A,B,C block color is red,the D block is blue, and the Other block is gray.How can i achieve it?
Reply #7 - Jun 17th, 2013 at 5:39am
You can assign brushes for the individual pie pieces through the PieChart.Brushes property. For example, you can do that in XAML like this:
<ResourceDictionary
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:r="http://mindfusion.eu/reporting/wpf">
<x:ArrayExtension Type="{x:Type Brush}" x:Key="PieBrushes">
	<SolidColorBrush Color="#FF0000" />
	<SolidColorBrush Color="#0000FF" />
	<SolidColorBrush Color="#C0C0C0" />
</x:ArrayExtension>
<r:PieChart Brushes="{StaticResource PieBrushes}"  />
cfn_zzq
Reply #8 - Jun 17th, 2013 at 8:52am
The property of PieChart Brushes is set by code. I don't know why it does not display?
myReport.QueryDetails += (s, e) =>
MindFusion.Reporting.Wpf.PieChart pieChart = s as MindFusion.Reporting.Wpf.PieChart;
if (item != null)
List<Brush> lst = new List<Brush>
new SolidColorBrush(Color.FromRgb(Convert.ToByte(110),Convert.ToByte(110),Convert.To
Byte(110))),
pieChart.Brushes = lst;
e.Details = ...
Reply #9 - Jun 17th, 2013 at 9:40am
More appropriate place to customize appearance would be the Prerender event. There you can directly customize the appearance properties of the rendered PieChart:
var pieChart = e.RootVisual as MindFusion.Charting.Wpf.PieChart;
if (pieChart != null)
	pieChart.Series[0].Fills.Clear();
	pieChart.Series[0].Fills.Add(new SolidColorBrush(Color.FromRgb(110, 110, 110)));
Note that RootVisual is an instance of MindFusion.Charting.Wpf.PieChart and not the original MindFusion.Reporting.Wpf.PieChart report item.
cfn_zzq
Reply #10 - Jun 18th, 2013 at 2:49am
Thanks for your help.
