Normal Topic Best diagramming Version (Read 2745 times)
alukes
Jul 29th, 2013 at 5:06pm
What diagramming version is the easiest to use with Java EE managed beans?  Which version has the least impact on the server? It looks like my choices are the Java or Java Script versions.
Re: Best diagramming Version
Reply #1 - Jul 29th, 2013 at 5:32pm
If you need to work with the diagram DOM objects on Java EE server, your best option is the Java library.
For least server impact, you could offload most processing to the client (such as populating and arranging the diagram) and use the server only for storage. In that case you can use any of our libraries that run in a browser (Java, JavaScript, Silverlight, ActiveX) depending on the target operating systems and browsers you need to support.
