We have released version 1.1 of MindFusion.Scheduling for Java Swing. The new version includes:
Item EffectsThe new Glass and Aero visual effects can be applied to items. To apply an effect, create an instance of one of the effect classes, set up its properties, then add the instance to the AwtCalendar.ItemEffects collection. Currently, there are two effect types available - AeroEffect and GlassEffect. Effects can be added, removed or modified at any time and this will immediately reflect on the calendar. Effects of different types can be applied simultaneously. It is also possible to apply more than one effect of the same type. For more information about effects, visit the Item Effects topic.
Custom GroupingCustom grouping represents the ability to specify the secondary resources individually for each primary resource. This can be done through the new customizeGrouping event. Grouping can now also be enabled by the runtime type of resources, rather than just the four predefined categories.
New EventsThe CalendarListener interface exposes several new events, in addition to customizeGrouping - beginItemDrawing, itemDrawing, endItemDrawing, and filterItem.
Miscellaneous- Fixed a bug that prevented styled item texts from appearing.
- The getExactDateAt method works more consistently in various scenarios.
- New setViewport method.
A trial version (including samples) is available for download here:
https://mindfusion.eu/JPlannerTrial.zipAdditional information about the library can be found in the Online Documentation:
http://mindfusion.eu/onlinehelp/jplanner/index.htmEnjoy!
