Normal Topic How we can create diagram like Database diagrams - ER diagram (Read 6636 times)
Todkar
Oct 7th, 2013 at 5:59am
I am trying to create ER diagram like database diagram [Find the attached sample image];
but not yet succeed.
can you please help me on same;
which approach should I follow to create diagram like ER / Database diagram.
Is any layout provided for ER diagram ?
I am using Silverlight + MindFusion latest versions
it will good if you provide me sample example.
Thanks a lot,
Jayraj
Re: How we can create diagram like Database diagrams - ER diagram
Reply #1 - Oct 7th, 2013 at 8:58am
You could create TableNodes to display tabular data such as class members or DB field definitions. Arrange them using OrthogonalLayout, or another layout combined with OthogonalRouter. Here's a sample diagram:
for (int i = 0; i < 10; i++)
	var table = diagram.Factory.CreateTableNode(0, 0, 100, 100,
		2 /* columns */, 5 /* rows */);
	for (int r = 0; r < 5; r++)
		table[0, r].Text = "field " + r;
		table[1, r].Text = "int";
	int d1 = (i * 7 + 2) % diagram.Nodes.Count;
	if (i == d1)
		continue;
	diagram.Factory.CreateDiagramLink(
		diagram.Nodes[i], diagram.Nodes[d1]);
	int d2 = (i * 2 + 1) % diagram.Nodes.Count;
	if (i == d2)
		continue;
		diagram.Nodes[i], diagram.Nodes[d2]);
new OrthogonalLayout().Arrange(diagram);
/*var ll = new LayeredLayout();
ll.Orientation = MindFusion.Diagramming.Layout.Orientation.Horizontal;
ll.Arrange(diagram);*/
new OrthogonalRouter().Arrange(diagram);
