Normal Topic ScheduleView Control- Timeslot selection feature (Read 3225 times)
Sooriya29041989
Oct 29th, 2013 at 6:15am
I want to use Scheduler control in my application. I wanted to check if the control has option to select timeslots and display only the selected timeslots.
Currently I can filter the timeslot by setting start time and end time
Example: If Start time - 8:00 PM and End time - 11:00 PM
It displays the timeslot as below (in week view) :
     Monday      Tuesday      Wednesday      Thursday 8:00 PM
8:30PM
9:00PM
9:30PM
10:00PM
10:30PM
Please let me know whether the time slot in Scheduler can be implemented as shown below.
If user wants to see only for 8, 8:30, 10, 11 then grid have to be displayed as:
8:30PM
10:00PM
11:00PM
Please let us know if there is any other control  which supports the above scenario.
Re: ScheduleView Control- Timeslot selection feature
Reply #1 - Oct 29th, 2013 at 7:00am
You cannot display irregular time intervals in the Timetable view. What you can do is hide some of the dates displayed in the timeline, but in this case the visible times will be spaced unevenly. For example 8:00 and 8:30 will be closer together than 8:30 and 10:00. To hide specific texts from the timeline, you can use the CustomizeText event. For example, to hide the texts corresponding to 9:00, 9:30 and 10:30 in the range 8:00-11:00, use the following code:
calendar.CustomizeText += calendar_CustomizeText;
calendar.TimetableSettings.StartTime = 60 * 20;
calendar.TimetableSettings.EndTime = 60 * 23;
calendar.TimetableSettings.GroupHours = State.Disabled;
calendar.TimetableSettings.TimelineSize = 60;
calendar.TimetableSettings.CellSize = 50;
void calendar_CustomizeText(object sender, CalendarTextEventArgs e)
	if (e.Element == CalendarTextElements.TimetableTimeline)
		if (e.StartTime == TimeSpan.FromHours(21.0) ||
			e.StartTime == TimeSpan.FromHours(21.5) ||
			e.StartTime == TimeSpan.FromHours(22.5))
			e.Text = "";
I hope this helps.
