Normal Topic Installation on Buildcontroller (Read 3210 times)
Denis Häußer
Nov 22nd, 2013 at 12:43pm
Is it possible to install MindFusion (Trial) on a TFS Buildcontroller/-agent.
Re: Installation on Buildcontroller
Reply #1 - Nov 22nd, 2013 at 12:59pm
It should be possible. If you have a lot of build systems, you could just copy the assemblies to each of them and import the following registry key, exported from a system where you have run the full setup:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\MindFusion\ComponentLicenses
