Normal Topic Line Drawing (Read 1438 times)
calace
Just WPF It
Line Drawing
Nov 23rd, 2013 at 3:34am
I would like to know how to create a line drawing annotation that is contained in the node properly. Is there an example on how to do this? I would like the line to have the ability to rotate. I tried using UIElement and it works as horizontal but once I rotate it to vertical the line drawing goes outside the node boundary.
Re: Line Drawing
Reply #1 - Nov 25th, 2013 at 9:31am
If that line is where you want it, but you only need to prevent it from sticking out of the node, try setting the node's ClipToBounds property.
