Quote:1. can i use button and label control in the time table view each appointment?
You cannot display controls inside appointments. You can simulate button and label by using custom drawing or custom item viewer and handling the ItemClick event of the Calendar. If you need these controls to be visible only when the item is in-place edited, you can use a custom item editor.
Quote:2. how to use the styled text in the appointment header text?
This is not possible. Currently styled texts can be used only in the item's description.
Quote:3. how to appointment header text specific word with background color?
This is not possible out-of-the-box. You have to rely on custom drawing and perform the necessary painting manually.
Quote:3. how to place the my own icons in the end of each appointment header text?
If you need to display a single icon, you can assign it to the Image property of the item's Style. If you need to display more than one icon, you need to use custom drawing. You can check the AdvancedItemDrawing sample to see how you can do this and more.
