Normal Topic TreeLayout Diagram - ScrollViewer and Alignment problems (Read 11711 times)
nagarjuna
Jan 7th, 2014 at 7:20am
Im using TreeLayout to Layout a diagram with few nodes.
but,
I am having problems with having scrollviewer & aligning the tree to the center of the diagram
1.using scrollviewer is only showing the vertical scrollbar, horizontal scrollbar is not being shown
2.how do i align the tree to the center of the diagram?
(or)
make the root node to the center(so that its position can be kept the same in the TreeLayout, thereby making the tree still centered?
I have programmatically set the Bounds for the rootNode(such that it appears center) and set the TreeLayout.KeepRootPosition to true, but still, after the no of items increase - the horizontal scrollbar doesnt appear and the root node keeps shifting
here's the xaml file and code behind :
Code (HTML)
        <Grid x:Name="LayoutRoot" Background="White">
        <ScrollViewer HorizontalScrollBarVisibility="Auto" VerticalScrollBarVisibility="Auto">
        <mindfusion:Diagram x:Name="diagram" Loaded="diagramm_Loaded"></mindfusion:Diagram>
        </ScrollViewer>
    </Grid>
Code (Java)
        private ShapeNode rootNode;
        private TreeLayout treeLayout;
        public MainPage()
            InitializeComponent();
        private void diagramm_Loaded(object sender, RoutedEventArgs e)
            this.rootNode = new ShapeNode(this.diagram);
            this.rootNode.Bounds = new Rect(new Point(this.diagram.Bounds.Width / 2 - this.rootNode.Bounds.Width / 2, this.rootNode.Bounds.Y), new Size(this.rootNode.Bounds.Width, this.rootNode.Bounds.Height));
            this.diagram.Nodes.Add(this.rootNode);
            //// add 12 children nodes under the root node
            ShapeNode child;
            for (int i = 0; i < 12; i++)
                child = new ShapeNode(this.rootNode);
                this.AddChild(this.rootNode, child);
            //if (this.treeLayout == null)
                this.treeLayout = new TreeLayout(this.rootNode, TreeLayoutType.Centered, false, TreeLayoutLinkType.Straight, TreeLayoutDirections.TopToBottom, 100, 100, true, new Size(0, 0), true);
            treeLayout.Arrange(this.diagram);
        private void AddChild(DiagramNode parent, DiagramNode child)
            this.diagram.Nodes.Add(child);
            DiagramLink link = new DiagramLink(this.diagram, parent, child);
            this.diagram.Links.Add(link);
Could someone help me with this?
Thank you,
Nagarjuna
Re: TreeLayout Diagram - ScrollViewer and Alignment problems
Reply #1 - Jan 7th, 2014 at 8:59am
Call Diagram.ResizeToFitItems() after TreeLayout.Arrange().
nagarjuna
Reply #2 - Jan 7th, 2014 at 1:46pm
wow!, that helped with the HorizontalScrollBar
but, that is not helping with positioning the tree properly!!
every time a new node gets added - the Tree shifts its position
can the rootNode's position be kept fixed(at the center of the whole diagram)?
thank you..
Reply #3 - Jan 7th, 2014 at 2:37pm
KeepRootPosition should preserve the diagram coordinates of the root node, but once you resize the diagram, its scroll position might change and the node will move to a different screen position. Try setting diagram.ScrollX = rootNode.GetCenter().X - scrollViewer.ActualWidth / 2 after resizing the diagram to make sure that node is centered visually.
nagarjuna
Reply #4 - Jan 8th, 2014 at 7:42am
Hi Stoyo,
sorry, but that is not helping!!
I think there is some misunderstanding, I might have not made it clear...
I dont want the rootnode to appear center to the VisualScreen(i.e no necessity of manually moving the scrollbar such that the rootnode appears at the center of visual screen)
I want the rootnode to not shift its position(which will be at the center of the whole screen width, not the visual screen)
My requirement is this :-
1.A tree whose root node which initially sits at Top-Center position.
2.Upon expanding the Tree - the root node should not change its position(it should be fixed).
3.if the diagram takes more space - then scrollbars will be helping to navigate to particular place in the tree
without the Diagram.ResizeToFitItems() call, both 1 & 2 are possible. its only that in requirement 3 - the horizontal scroll bar is not appearing.
even If i used Diagram.ResizeToFitTItems(), i believe its supposed to just adjust the width/height, but, why is it repositioning the tree nodes(especially the root node) even when the horizontalscrollbar is not activated?
(i.e in the beginning, where there are few nodes and the width is sufficient and horizontal scrollbar is not activated - i still see that the root node gets shifted upon ading child nodes)
thank you
Nagarjuna
Reply #5 - Jan 8th, 2014 at 12:00pm
You will have to save and restore the scroll position then. Restoring scroll position might not work if the diagram grows smaller (e.g. old scroll X gets outside new bounds), so instead of calling ResizeToFitItems, create a union of current diagram.Bounds and the new diagram content rect:
var scrollX = diagram.ScrollX;
var scrollY = diagram.ScrollY;
var tl = new TreeLayout
	Root = e.Node,
	KeepRootPosition = true
tl.Arrange(diagram);
var newBounds = diagram.Bounds;
newBounds.Union(diagram.GetContentBounds(false, true));
diagram.Bounds = newBounds;
diagram.ScrollX = scrollX;
diagram.ScrollY = scrollY;
nagarjuna
Reply #6 - Jan 9th, 2014 at 6:20am
hi,
yeah, that helps (although, the root node still keeps shifting a bit, i guess i just have to live with that  Smiley)
thanks for all the help
Nagarjuna
Reply #7 - Jan 9th, 2014 at 7:16am
I can see it shift only if you start with a diagram.Bounds smaller than the scroll viewer's size. ScrollViewer does no let you change scroll position when its content is smaller. If you start with a large enough initial diagram.Bounds, the root should stay fixed on screen with the code above.
