Normal Topic DiagramPage's alignment within Viewport (Read 1219 times)
GregC
Jan 21st, 2014 at 11:31am
If a DiagramPage's Bounds are smaller than the Viewport, then the DiagramPage is shown centrally aligned within the DiagramView.  Is there a way to have it top left aligned instead ?
Regards
Greg
Re: DiagramPage's alignment within Viewport
Reply #1 - Jan 21st, 2014 at 1:10pm
It doesn't seem possible. That depends on ScrollViewer used in TabbedDiagramView's template, and I can't find any way to left-align ScrollViewer's content if it is smaller than viewport. If you know of any way to do that, you could customize the ScrollViewer's Xaml in the template. Otherwise you could set diagram.Bounds to the union of the viewport and current Bounds value to make sure it doesn't get smaller than the viewport.
