Normal Topic Word wrap problem if UseStyledText is enabled (Read 3243 times)
Torsten H
Feb 5th, 2014 at 10:32am
after having set Calendar.ItemSettings.UseStyledText to State.Enabled, word wrap doesn't work correctly. In timetable view, the Item.DescriptionText isn't wrapped inside words, only between words. And what's more, if a word inside the text doesn't fit (exceeds) the width of a calendar item, this word and any text after it is cut off! TextAlignment.NoWrap isn't set, this flag is ignored for styled text anyway.
If UseStyledText is disabled, word wrap works as expected.
Is it a known problem? Is there a property or a workaround to avoid this effect?
Torsten
Re: Word wrap problem if UseStyledText is enabled
Reply #1 - Feb 5th, 2014 at 1:45pm
This behavior is by design. We will look into ways of extending the styled texts to support character wrapping for the next release, which is expected until the end of the week.
Reply #2 - Feb 5th, 2014 at 3:42pm
Check out this version:
https://mindfusion.eu/_temp/MindFusion.Scheduling.5.4.2.trial.zip
Styled texts should now be displayed more consistently with regular texts.
