Hot Topic (More than 10 Replies) Including custom text in pdf (Read 5989 times)
M Isabel Cabeza
Mar 24th, 2014 at 10:06am
Hello
I have used this component to represent diagrams in my windows application. Where diagram can be exported to pdf, but as I use the mindfusion export method, I get a pdf file with the diagram image at the end. I would like to add some custom text as header and footer or at least at the begining of the pdf document. Is this posible with the ofered api? is There any way of doing this??
Thanks a lot in advance
Kind regards
Re: Including custom text in pdf
Reply #1 - Mar 24th, 2014 at 12:41pm
Try custom-drawing it from DrawBackground or DrawForeground event handler:
private void diagram_DrawForeground(object sender, DiagramEventArgs e)
	var graphics = e.Graphics as PdfGraphics;
	if (graphics != null)
		var pageContentRect = e.ClipRect;
		var font = new Font("Arial", 10);
		graphics.DrawString(
			"header", font, Brushes.Black, pageContentRect,
			new StringFormat
				Alignment = StringAlignment.Center,
				LineAlignment = StringAlignment.Near
			"footer", font, Brushes.Black, pageContentRect,
			new StringFormat
				LineAlignment = StringAlignment.Far
		font.Dispose();
You could insert a title page by exporting a DiagramDocument, whose first page displays the text you want, and the second page is set to the actual diagram content. You could either assign the title text to a single transparent ShapeNode on the first page, or custom-draw it as above.
M Isabel Cabeza
Reply #2 - Mar 24th, 2014 at 2:26pm
I have test this code, but it does not seems to work. I am using a  PdfExporter and calling  "pdfExporter.Export(FlowChart, fileName);" and this is not redrawing neither foreground or background, although I amd registering the event.
any idea???
Reply #3 - Mar 24th, 2014 at 4:04pm
What version of the control are you using?
M Isabel Cabeza
Reply #4 - Mar 24th, 2014 at 4:16pm
the MindFusion.Diagramming.Export.Pdf.dll is the version 5.8.0.23716. the control is 5.8.0.23715
Reply #5 - Mar 25th, 2014 at 8:01am
That also worked with version 5.8 for me, using default PdfExporter settings. What does your export code look like?
M Isabel Cabeza
Reply #6 - Mar 25th, 2014 at 9:05am
Something like this:
    var pdfExporter = new PdfExporter
                    AutoScale = PdfExportOptions.Instance.PdfAutoScale,
                    InvisibleItems = PdfExportOptions.Instance.InvisibleItems,
                    Margins = PdfExportOptions.Instance.Margins,
                    PageOrientation = PdfExportOptions.Instance.PageOrientation,
                    PageSize = PdfExportOptions.Instance.PageSize,
                    Scale = PdfExportOptions.Instance.PdfScale,
            // Remove the expandable sign from nodes
            var expandableNodes = new List<MindFusion.Diagramming.DiagramNode>();
            foreach (var node in FlowChart.Nodes.Cast<MindFusion.Diagramming.DiagramNode>().Where(node => node.Expandable))
                expandableNodes.Add(node);
                node.Expandable = false;
            DiagramItemCollection oldFlowChartSelection;
            SelectionBlock oldSketchMatrixSelection;
            bool oldShowSketchMatrixGridLines;
            // Store selection
            DeselectFlowChartItemsBeforeExport(out oldFlowChartSelection, out oldSketchMatrixSelection, out oldShowSketchMatrixGridLines);
            // Special case, when generating the WMF image the RTF nodes has to have
            // the IsPrinting property to true in order to right calculate the size for the
            // custom draw for that nodes
            foreach (DiagramNode node in _diagramNodes.Values)
                if (node is RTFNode)
                    (node as RTFNode).IsPrinting = true;
            try
                // Get this old zoom and scroll values for restore after printing
                oldZoomFactorForPrint = diagramView.ZoomFactor;
                oldScrollX = diagramView.ScrollX;
                oldScrollY = diagramView.ScrollY;
                diagramView.ZoomFactor = 100;
                pdfExporter.RenderOptions.Scale = 100;
                if (!bUnattended)
                    Process.Start(fileName);
            catch (Exception exc)
                MessageBox.Show("An error occured during the export to PDF. The diagram may contain elements that are not supported by the PDF exporter.\n" + exc.Message, "Error in export to PDF", MessageBoxButtons.OK, MessageBoxIcon.Information);
                Handler.Show(exc);
Reply #7 - Mar 26th, 2014 at 8:38am
What settings are there in PdfExportOptions when it doesn't work? I got the attached PDF file with following code:
private void button1_Click(object sender, EventArgs e)
	saveFileDialog.DefaultExt = "pdf";
	saveFileDialog.Filter = "PDF files|*.pdf";
	if (saveFileDialog.ShowDialog() == DialogResult.OK)
		var pdfExporter = new MindFusion.Diagramming.Export.PdfExporter
			AutoScale = MindFusion.Diagramming.Export.AutoScale.FitToWidth,
			InvisibleItems = true,
			Margins = new Margins(10, 10, 10, 10),
			PageOrientation = PageOrientation.Landscape,
			PageSize = PageSize.A4,
			Scale = 100,
		pdfExporter.Export(diagramView1.Diagram, saveFileDialog.FileName);
			new StringFormat
			new StringFormat
		font.Dispose();
If you set a breakpoint inside DrawForeground handler, does the debugger ever stop there when you export?
test_header.pdf (Attachment deleted)
M Isabel Cabeza
Reply #8 - Mar 26th, 2014 at 10:19am
I should have introduced an error because now it is working!!! thanks a lot!!!  Wink Wink Wink
Kind regards !!!
M Isabel Cabeza
Reply #9 - Apr 1st, 2014 at 1:46pm
Now another problem comes up. The diagram is exported using a PdfExporter, and the image of the diagram overlaps with the header.
Is there anyway to tell the exporter where to start writting? I have put the header and the footer in the flowChart_DrawBackground event.
Thansk a lot!
Reply #10 - Apr 1st, 2014 at 6:39pm
If you mean drawing text in the margin area, you could in theory achieve that by inflating the target rectangle a bit:
pageContentRect.Inflate(5, 5);
However the control always clips content at the page margins at this time, so you won't see the headers then. We'll try to add an option to disable that clipping and implement built-in headers support for next release.
Meanwhile you could use some third-party PDF processing library to remove the clip command before header text, or even modify the PDF file directly by loading it into a string and modifying the clip parts. The PDF mark-up for the header above will look like this:
36 36 522.9999 769.9999 re W n
(header)  Tj
You can remove the clip region by replacing the "re W n" commands with "re n n".
M Isabel Cabeza
Reply #11 - Apr 3rd, 2014 at 7:39am
Thanks, we will keep on looking for solutions.
Reply #12 - Apr 14th, 2014 at 1:12pm
This version adds HeaderFormat, HeaderFont, FooterFormat, FooterFont properties to PdfExporter:
https://mindfusion.eu/_beta/fcnet613.zip
Similarly to PrintOptions.HeaderFormat, %P is placeholder for current page number:
pdfex.HeaderFormat = "page %P";
pdfex.FooterFormat = "copyright 2014";
pdfex.Export(diagram, sfd.FileName);
