Normal Topic The horizontal scrollbar is not showing (Read 1752 times)
Ada
Apr 7th, 2014 at 9:23pm
Hi There,
My diagram is big enough to show the scroll bar,  but only the vertical one is showing, not the horizontal one.
If I move another node to the right out of the diagram border, the horizontal scroll bar will show up and then I can see the whole diagram.
What should I do to show up both scroll bar?
Thanks.
Ada
Re: The horizontal scrollbar is not showing
Reply #1 - Apr 8th, 2014 at 6:32am
Set larger diagram.Bounds or call ResizeToFitItems after populating and arranging the diagram.
Ada
Reply #2 - Apr 9th, 2014 at 12:50am
It works, thanks.
Ada
