Normal Topic Version 4.1 beta (Read 3686 times)
Version 4.1 beta
Jun 13th, 2014 at 11:02am
JDiagram version 4.1 adds the following new features:
Composite nodes
The CompositeNode class implements nodes whose appearance can be defined via composition of components and layout containers. The content of a composite node can be loaded from XML files similar to .NET Xaml templates and Android XML layouts. This initial release includes layout containers such as StackPanel and GridPanel, and read-only components like ImageComponent, TextComponent, ShapeComponent, BorderComponent. Future versions will add interactive components like buttons and text editors.
Export Visio 2013 files
The VisioExporter class can export the content of Diagram and DiagramDocument objects to Visio 2013 VSDX files. In order to use it, import the com.mindfusion.diagramming.export namespace. VisioExporter relies on a template file, called Visio2013.vxt, containing some boilerplate Visio XML code. The template must be either located in same folder as the application, or its path must be specified via the TemplatePath property. At this time the exporter supports shapes from Visio basic stencil. Support for more shapes will be added upon request.
~ Improved PdfExporter performance.
~ VisioImporter now supports Visio group shapes. Child shapes in groups are no longer lost when importing, and their corresponding diagram nodes are attached to the corresponding group node.
If anyone is interested in trying the beta version, please download this archive containing the updated jar file and a sample project demonstrating CompositeNodes:
https://mindfusion.eu/_beta/JDiagram41.zip
