Normal Topic MindFusion.Scheduling for WPF, version 3.3 (Read 2682 times)
Jun 13th, 2014 at 12:43pm
We have released version 3.3 of MindFusion.Scheduling for WPF. The new version includes:
Visual Studio 2013 support
MindFusion.Scheduling for WPF now includes support for Visual Studio 2013. The installer can create VS2013 toolbox palette for the component, and can optionally install VS2013 sample projects.
Improved data grid
The cells and headers in the data grid can now be customized through a set of new properties: CellBorderBrush, CellBorderThickness, HeaderBackground, HeaderBorderBrush, HeaderBorderThickness, HeaderFontSize, HeaderForeground, and HeaderMargin. The new ColumnCreating event can be used to replace a grid column with a custom one.
New Holiday Providers
Five new holiday providers have been added to the MindFusion.HolidayProviders.dll assembly, namely AustraliaHolidayProvider, FranceHolidayProvider, GermanyHolidayProvider, RussiaHolidayProvider, and UKHolidayProvider.
Improved Timetable view
The WorkTimeStartHour and WorkTimeEndHour properties have been renamed to WorkTimeStart and WorkTimeEnd respectively and are now of type TimeSpan to allow more flexible work time intervals. In addition, the new WorkTimeStarts and WorkTimeEnds properties can be used to specify different work time intervals for the different days in the view. The new ColumnHeaderTemplate property can be used to customize the column headers by using a DataTemplate object.
Improved WeekRange view
The Week Range view can now display week numbers, similarly to the Single Month view. The week numbers can be enabled through the WeekHeaderPosition property and can be customized through the RotateWeekHeaderTexts, WeekHeaderFormat, WeekHeaderStyle, and WeekNumbersHeaderWidth properties.
Improved Resource view
The row headers can be customized through the new RowHeaderTemplate property.
  • New resource and item hit-testing methods: GetItemAt and GetResourceAt.
  • The modifier key to clone items interactively can now be specified through the ItemCloneKey property.
  • New ItemStartModifying event.
  • Various bug fixes.
  • Two new samples - CustomMonthCalendar and CustomTimetableGrid.
https://www.mindfusion.eu/WpfPlannerTrial.zip
« Last Edit: Jun 16th, 2014 at 6:23am by Forum Admin »
