We have released version 2.2 of MindFusion.Diagramming for ASP.NET MVC. It adds the following new features:
SVG NodesThe SvgNode class represents nodes that can display SVG drawings. SVG graphics are rendered instead of Image, and on top of the geometry rendered by the base ShapeNode class. The SVG drawing of a node is specified through its SvgUrl property.
jQuery supportNow the control can use jQuery for browser abstraction instead of Microsoft Ajax. To choose between Microsoft Ajax and jQuery support, set the ClientSideMode property.
Visio2013Exporter improvements~ Support for multi-segment links
~ Bezier links are now exported as NURBS lines
~ Support for rotated nodes
~ Proper scale for all MeasureUnit values
~ Support for semi-transparent colors
Miscellaneous~ Set the BackgroundImageUrl property to draw an image as Diagram's background.
~ The TextStyle property of links provides support for several different text position and orientation styles, defined by the LinkTextStyle enumeration.
~ Set the AllowUnconnectedLinks property to true to let users draw links without connecting them to nodes.
~ OrthogonalLayout no longer ignores repeating links, and will now place them at a distance specified via RepeatingLinksPadding property.
clients area on our site.
https://www.mindfusion.eu/MvcDiagramTrial.zip Enjoy!
