Normal Topic Auto Align (vertically / horizontally) with other nodes with almost the same (X / Y) position (Read 4507 times)
dossantos
Jul 23rd, 2014 at 9:26am
I'd like to achieve some auto-aligning similar to the WinForms Designer of VS, as in:
when dragging a node, and...
- its current Y-Coordinate is near the Y-Coordinate of some other node, snap to that Y-Coord. and display a helper line across the diagram through the top of that node.
- its current Y-Center is near the Y-Center of some other node, snap the center to that Y-Coord. and display a helper line across the diagram through the Y-Center of that node.
- same for Bottom
- similarly for X-Coordinates (Left, Center, Right).
This will help aligning Nodes horizontally and vertically. Is this implemented? (I think Diagram.AutoAlignNodes works differently, right?). So what would I need to do to achieve this? In the NodeModifying-Event, I seem not to be able to change the bounds of the dragged node:
Code (C++)
        private void HandlesNodeModifying(object sender, NodeValidationEventArgs args)
                const float Delta = 1f;
                var node = args.Node;
                var db = this.Diagram.Bounds;
                var same = this.Diagram.Nodes.Except(new[] { args.Node })
                                                    .FirstOrDefault(n => Math.Abs(n.Bounds.Y - node.Bounds.Y) < Delta);
                if (same!= null)
                    node.Bounds = new RectangleF(node.Bounds.X, same.Bounds.Y, node.Bounds.Width, node.Bounds.Height);
                same= this.Diagram.Nodes.Except(new[] { args.Node })
                                                .FirstOrDefault(n => Math.Abs(n.Bounds.X - node.Bounds.X) < Delta);
                if (same!= null)
                    node.Bounds = new RectangleF(same.Bounds.X, node.Bounds.Y, node.Bounds.Width, node.Bounds.Height);
PS: sorry for the amount of questions lately Smiley
Re: Auto Align (vertically / horizontally) with other nodes with almost the same (X / Y) position
Reply #1 - Jul 23rd, 2014 at 9:40am
That's what AutoAlignNodes does, set it to true.
dossantos
Reply #2 - Jul 23rd, 2014 at 2:16pm
Thanks, that kind of works, but what if I (for whatever reason) wish to do it manually.
Is there a possibility to update a node's Bounds while the user is dragging it? (Inside the NodeModifying handler it doesn't seem to work).
Cheers,
Tim
Reply #3 - Jul 23rd, 2014 at 4:09pm
Why the "kind of"? AutoAlignNodes works fine from what I can see. You can change Diagram.AutoAlignDistance if you want aligning to borders at a larger distance.
NodeModifying is a validation event raised before the control sets actual new node .Bounds value calculated from current mouse position. We could add a Bounds event argument for next release if you want to specify new position from the NodeModifying handler. Or if you are using a custom node type, you could set your preferred position from UpdateModify override.
dossantos
Reply #4 - Jul 25th, 2014 at 8:29am
The "kind of" means that it aligns the nodes, yes, but I want to do some extra steps when aligning, and I may need some custom alignment rules on top of "align to border within AutoAlignDistance".
So, a read/write "bounds"-Property on the NodeValidationEventArgs would help me a lot - thanks for adding this (if you may)!
Tim
Reply #5 - Jul 29th, 2014 at 5:21pm
This build adds an OverrideBounds member to NodeValidationEventArgs:
https://mindfusion.eu/_beta/fcnet63.zip
If you set it from the NodeModifying event handler, the node will be placed at specified position.
dossantos
Reply #6 - Jul 30th, 2014 at 11:14am
Perfect! Thank you!
(btw, convincing my boss to buy MindFusion diagramming is in progress Wink getting this quality of support while still in evaluation is pretty awesome!)
Reply #7 - Jul 30th, 2014 at 12:01pm
best of luck Cool
